I have more problems, it's a 69 fj40 and the mini parts donor is a 84, got it all together with new flex lines, the flex line mates to the hard line from the caliper but the line from the mc is a smaller fitting, drove 60 miles to a kalsipel, no luck with any parts store, only suggestion was to replace the hard line to the mc. ok i think this would be easier than running all over the state but on the way home i'm thinking what about the rear axel, I cannot run new lines to the rears drums without the same adapter fitting i need for the front. would someplace like industrial supply have something that i could use or has someone else had this problem? I think the fem end on the hose is 8mm and the hard line is smaller it will slide right in. passed up a mud bog contest just 4 miles away today thinking i would get this done. it took a hour nap to cool off. I hope someone out there can help me with some insight to this problem i have searched the tech files and none seem to address this. my plan is as follows:
75 vette nb mc- sae to 8mm hardline adapter to paportional valve from a pickup to these smaller metric fittings. thnx
