I've read and read and read and read the threads....and need some final input on XML's.
Greetings,
I was directed over to the 80 forums by my 80-driving friends to supply an opinion on a topic I am quite passionate about… Michelin Military tires.
I ran the 325/85/16 XML’s on my S/O BJ74 for many years. Here’s my thoughts.
My first advice is to get them siped. This will help with traction.
The rubber is actually relatively soft, and sticks to the rocks really well. I ran the XML’s over the Rubicon without lockers, and other than getting wedged into Volkswagen rock, never got stuck. The reason I had no lockers is because I twisted a rear axle on Walker Hill that jammed up the locker gear. Didn’t break the axle, but couldn’t engage the locker. Is this ‘breakage’ because of the tires, or because I was running 250:1 gearing through the one tire I had on the ground, wedged between rocks? The tire had the traction, can’t blame it for that!
I ran the XML’s sister tires, the XL’s, on Moab last spring , and was never wanting for traction. I think I spun rubber maybe three times all week. Great traction. The reason those tires are bullet proof is not because of rock hard rubber, but 4 layers of steel belting in the tread, and even a layer of steel belting in the sidewall. That’s why they are so strong! The rubber is a bit better softer than your average MT, I would say.
The only other thing I broke of note was a birfield. I was trying to turn around on a trail to go back and pull someone out of the mud… cranked the wheels to full lock, reverse, and with one wheel jammed in a rut, instantly snapped a birf. Is that because I had big heavy tires, or because I was at full lock in reverse with a tire wedged in a rut? That’s what I thought too.
Let’s get real. Your tires don’t break parts. How you drive breaks parts. The weight of the tire makes them hard to balance, but doesn't in itself contribute to breakage. The sticky tires and the 18" of leverage that your torqe acts upon may break stuff, but you can't blame your tire for sticking to the rocks! Drive accordingly.
The Micheling Military tires, especially the XL’s, but also the XML’s, absolutely come alive on gravel or dirt roads. They eat rough roads for lunch. This is what they were designed for, after all.
They are terrible on ice and wet pavement. Siping helps, but this is the big weakness. They are hard to balance. On dry pavement they are surprisingly good. Loud, but not ridiculous. They are radials, so the track nicely down the road. The rubber is soft, so expect about half the life of the all-terrains on your mom’s K car.
I destroyed one tire when it got peeled fully off a rim in a very bad situation. Never could balance it after that. I moved into Iroks for crawling and winter use, and the Michelin XL’s for expedition type trips. The Iroks are a superior tire for traction, for sure, but I’ve had two sidewall leaks in on my Iroks. I never had a flat repair in the years of running the XMLs (well, if you excuse the time when I yanked a tire completely off a rim!) I trust the Michelins with my life, and are my go to tire for expedition trips when my well-being may be at stake. The Iroks are for fun, and come with an accessory called a Tow Rig and Trailer to get them home.
Hope this helps.
