For Sale Gilbert, Arizona 1994 Toyota Land Cruiser
Year
1994
  1. 80 Series
Mileage
241000
It comes with a heavy heart that I am saying this, but it is time for me to sell my Land Cruiser. Owning this Land Cruiser has been a blast I am really going to miss the Land Cruiser. But my family comes first.
The interior is in good shape for being a 26 year old rig. The dash does have some cracking from the Arizona sun but the rest of the interior is in great shape minus the seat wear on the drivers seat from sliding in and out. The paint is in not in the greatest, I call it sun kist. The right rear qtr panel has been sprayed tan using krylon rattle can.
The head gasket has been replaced. All the work was done by Scott Higgins when he was still working at Camelback Toyota. There is a slight miss but Scott believes that has to do with the wiring harness. He has recently checked the fuel pressure, cleaned the TB, cleaned the idle control valve. He believes that once the wiring harness is done the miss will be gone.
Interior modifications are slim. There is a CDL installed as well as some Delta VS storage brackets for a rear shelf. There is also a drawer system installed where the 3rd row used to be.
A Trail Gear front bumper has been installed along with tabs for light bars. I installed a 30” LED light bar in the front. Also, a Warn 9.5TI winch has been installed. The wire rope on the winch is brand new and never been used. The motor and brake have been replaced when Desert Rat Offroad rebuilt the winch for me.
The brakes have been replaced with slotted/drilled rotors from Rock Auto. The pads have been replaced twice since the rotors have been installed. Along with the rotors the factory rubber line were replaced with Slee stainless steel lines. When the lines were installed I also removed the ABS pump and the LSPV. After all the work the brakes were bleed multiple times using a vacuum pump. When removing the ABS pump I also removed the ABS wiring and ABS sensors and plugged the holes with the kit from Wits End. With the weight of the LC and the larger tires the Land Cruiser stops amazingly.
The suspension has a lot of work too. An OME lift has been installed using 850J and 860 springs with Ironman 4x4 30mm spacers on top of the springs with OME shocks at all four corners and a OME steering stabilizer. Dobinson sway bar drop bracket is installed in the front as well as Dobinson caster correction plates. The rear trailing arms have been replaced with Metal Tech 4x4 adjustable upper/lower control arms. A Delta VS pan hard bar bracket has been installed as well. Marlin Crawler is responsible for the upgraded steering. I installed their heavy duty upgrade kit with 555 ball joints.
The Land Cruiser is sitting on 315/75-16 BFG KO2 and has a brand new full size spare.
The knuckles need to be rebuilt but I do have the rebuild kit from Trail Gear with the wheel bearings that will go with the LC. The power steering pump needs to be replaced as well, I do have the pump as well. The oil pump seal, the crank shaft seal can/need to be replaced too.
I know there is some work that is needed but this rig is in great shape considering.
I am looking to get $12,500 but I am open to reasonable offers.
bump
I'm amazed this has not sold yet,. You have done a ton of work to this rig and at the prices rust free 80's are selling for, this one is a bargain for only needing a weekend worth of work/parts included.
You and me both. There are a lot of tire kickers but no one wants to pay to play.
what color is it? I can't really tell from the filtered image on the first post...
Nice truck...!
Nice truck...!
A green color originally, I will get the color code this weekend for you.
Added more detail to the post.
Hi Scott, I'm interested in your 80 if you still have it. Can you shoot me a PM?
I am looking to get $10,000 but I am open to reasonable offers.
Hey man I love your land cruiser! Are you interested in doing a trade plus cash? I have a 97 4runner with rear locker. I’ll send some pics if you’re interested, Thanks For your time!
Hard pass
Back up for sale
Interested in seeing more pics! Feel free to message or reach out! Bump!
Is there a good contact for you? Any preferred pictures you would like?
