Merge a 345 v8 from a IH Scout II into my 86 toyota fj60
Carterville, IL
i just recently acquired a 1986 toyota fj60 from my family. my brother burnt up the engine when a mechanical error happened. we suspect that the last time we took the suv in to get inspected and checked that the mechanic fxxxed up and didnt put everything back....... anyways so i just acquired the vehicle it has some minor area to be worked on but my major question is weather or not an 345 V8 from an International Harvester Scout II will merge just fine with my 4 speed trans or if i will need to get an adapter. As well as what type of v8 adapter kit will i need to drop the international into the housing........
Any information or if anyone has even tried this pics would be nice but would love the info. on how to if thats all i get haha
IMO that would be one colossal step backwards. While IH V8's have great low speed torque and a truly superior cooling system design, that's about all they have. Mileage is terrible, HP is terrible, they expensive to do major internal repairs on, they are the physical size of a big block Chevy, and they're at least as heavy as the 6 sitting in the engine bay now and maybe heavier.
I know that it's very "cookie-cutter", but a 350 Chevrolet is better in every aspect except possibly the low speed torque and definitely the cooling system - and that can be changed with a focused engine build for a lot, lot less than an IH engine can be built to have more HP (you've never solve the better efficiency riddle - the cyl heads are stacked against you and no amount of porting will fix the basic design flaw).
That said, the IH engines use a bellhousing that is significantly longer than pretty much any other engine. Their manual trans' input shafts are significantly longer than any other. Visit the AA tech pages if you want to know those details, but that means that the IH b/h isn't adaptable to the existing H-4X trans. And the IH b/h bolt pattern is unique to their engines so you aren't going to bolt a GM bellhousing on and then adapt it to the OE trans. So likely your best option is to adapt the T-18 or T-98 that is bolted to the IH engine to the Split Case t/c. In doing that you will go from a surprisingly nice shifting truck trans to a very typical shifting truck trans that lacks a synchro in first gear. Although if you're lucky your donor may have the 6.32:1 first geared T-18 instead of the more common 4:1 geared T-18.
About the only thing positive that I can say about such a swap is that once in there, it should be extremely simple to swap the IH gasser for the IH built Ford 6.9L or 7.3L IDI diesel.
Also, the 345 was never a popular engine for mods, and now it is so old that there is very little aftermarket support, and NO dealer support. John
I was more curious as to weather or not the swap was even possible. It is from an old scout we have oun land. A free engine is better then a cost one. but im also trying to think long term and gas efficiency. Granted this build wont take part right away bc i dont have the money to do so. Just like many people... but im looking for the best i can for what ive got. I might just take apart my 2f engine that is in it, figure out what parts are bad replace them, bore out the engine and put bigger pistons in it but still thats not a lot of power out of that engine for how heavy of a vehicle the fj60 is.
I have seen other swaps and noticed how much work goes into it. granted im game for it bc i love cars but i dont want to get halfway through it and then something stops me from finishing it and the vehicle just sits again for another 6-10 years.
Dang. That would merge about as well as traffic around here on a busy day.
Why not just a straight six out of a 1066 at that point??? Then you'd be turbodiesel, at least...
hee
t
You would be better off to just hunt down an old school 5.7 and pull the engine and matching transmission over the international V8.... cost would not be crazy if you ran an old carb GM V8 with a turbo 350 or 400....and you could do most of the work yourself.
Yea wanting to try and get an H55F trans. to drop in and merge with a nice v8 or possibly rebuilding the engine as ive already stated. Looked into the international and found out it would just suck me dry shoving it into the fj60. Gas mileage would be s***. and just to find parts would be hectic. but im not sure how far i could get as of now i need a motor lift to pull the engine out as is first off to see if i can even repair it. i may need to get the front differential a look over was leaking fluids when i moved it out of the barn it was sitting in...
My fj60 recently got some 2010 fj rims free and put them on the vehicle because the old rims were not in good shape
Not too hard to find a good running 2f to plant in it for the time being. Lot of work, but not so expensive to get you by for a while. John
