Master / Slave Key question
Burnet, Tx
2000 Land cruiser I purchased used came with 2 keys 1 black keyless entry and 1 gray key only.
If I put in the black key the security light stays on 1-2 seconds
if I put in the Gray key the security light goes out instantly.
I thought the gray key means its the valet key normally. But using this test it seems thats a master key right ?
So if the Gray key is a master I can I use it to reset the memorized keys via the info found all over the internet and then use it to program the black keyless entry key as a master so I would then have 2 masters ?
Thanks
