UPDATED: SEE POST #14
My SOA build is nearing completion as shocks are almost finished. My attention is now on brakes. The parts truck I bought came with SSBC front calipers and Chevy S-10 rear floating calipers. Due to the increased volume in brake fluid caused by the switch to disk brakes in the rear I am looking at a master cylinder upgrade. The few threads I have gone through during search show a lot of different approaches. I want to stick with a Toyota MC and am leaning towards an FJ80 MC or a T100 MC. Is there a MC that bolts directly up? I want to do the swap with as little modifications as possible. So, who can tell me which, if any model bolts directly up and will have a larger volume to accommodate the rear pistons on the Chevy S-10 calipers. The Chevy S-10 calipers look very similar to El Dorado calipers used by others and have the added benefit of using stock Toyota pads.
Second Question:
Assuming I can get a MC that bolts up, do I need to consider the bore and stroke of certain MC’s in order to keep the same pedal feel?
Third Question:
What is the benefit of keeping the LSPV? I can’t see any problems with taking it out other than skidding the rear tires during an emergency stop. This is normal to me and must be watched anyway as early 60 series had no ABS.
