Who here has used this adapter bellhousing to go from an LS to an H55F? Would you do it again or go NV4500?
First I'll qualify that as a mechanic I run out of talent fairly quick. In 2015 I purchased an E-Rod LS3 crate motor for my 1985 FJ 40, installed this with the Totota H55 5 speed tranny using the Marks 4WD conversion purchased through Advanced Adapters. This vehicle was summer use only very little use at my place in Montana, I always had "hard" shifting/downshift issues, just enough to finally say enough and get this addressed.
In consulting with Advanced (I purchased , (all parts, clutch, adapter etc from Advanced) I was told you have the wrong clutch as the LS crank is .400 closer to the tranny. 900.00 later, installed same issue. Again consulted with Advanced and was told that there is an updated itnterior/exterior sliding spline shaft for the Mark's kit . 1,400.00 later received the "updated" shaft, same exact shaft, mind you I am having all this work done at a very reputable shop in Bozeman. Again consulted via conference call with the tranny shop and Advanced, questions from Advanced were "are you sure there is not a burr on the shaft" .....really. Mind you all this time I'm paying to pull this tranny and assembly all this time.
Time to punt, we installed an NV 4500 tranny and it could not be sweeter, ratios are awesome shifting is effortless. the install was not without it's issues but at the end of the day....very nice.
Overall in my unprofessional opinion, the Mark's kit may be made for the 350 GM application but it is NOT made for the LS conversions as the .400 measurement kept raising its head. I tried consulting with Advanced all the way through this process, at the end of the day they were more of a hinderance
which has not been my previous experience. This was not an inexpensive project to get sorted out but I was determined to get this sorted.
I do have a H55 5 Speed tranny with a complete Mark's 4WD conversion for sale....(not for a LS3, for 350 Chevrolet conversion)
