After a close call with a driver who said he didn't see my turn signal
, I've decided to do the Marker Light mod. I'm going to replace the existing socket with a 90 degree 1157 socket I bought at O'Reilly, Calterm 08582. My goal is to keep the existing marker light function with the addition of the signal light function. I have hardly any electrical experience and none with automotive electrical applications, but I've decided to take Slee's advice and use it as a tool to learn about the vehicle, or else ask someone who knows to do it
On that note, I'm not exactly sure which turn signal line I tie each line from the signal to and which line ties in with the existing marker light. Does anyone have a diagram for this? I've read for the ARB bumper that you use the brown and green lines(I think) but I don't know which goes to which. The socket has three lines (white, brown, black)
I also read on a Heep site that I should use a relay somewhere, otherwise I will overheat the wires. They weren't exact on where to put it, so that's why I felt like I should ask if I even needed one.
I'm also not exactly sure how the best way to tie it in is either. I've soldered once a long time ago, and this might be a fun practice, or would "scotch locks" work just as well?
I'd also like to keep the signals blinking at the same time, and not with the alternating "disco" effect. Would this involve an upgraded flasher?
I've been researching this for awhile and all I've seen is suggestions for Slee's modification, swapping the turn signal and marker lights, or alluding to this mod. I plan on posting a writeup and pictures of this mod once I've completed it.
