manual pump feed to electric over hydrolic
crushers
post ho
Derwent Alberta
has anyone converted their slow hand pumped cylinders over to electric over hydrolic?
i have 2 portable E/H pumps, one for the hoist and the other for the press and i want to convert my pipe bender over to one of these, it would be time saving and much more enjoyable.:idea:
the cylinder shouldn't see the difference but i need to figure out how to either run a single line feed to the cylinder from a dual line (press) or just and adapter for the hoist to the cylinder.:confused:
anyone here schooled in hydrolics?:hhmm:
if this has been covered before just post up a link. :doh:
the dual action (compression and tension) electric mechanism would be very hard to convert to a pressure only system. Much easier to just use the hoist setup.
Although, you may need to swap out the ram as well.
How bout pics of everything..
actually i found an adapter that will work between the shop hoist and the pipe bender, tomorrow i will give it a try, if it works excellent, if it doesn't the cost is acceptable.
i will report back either way.
and the result is ...
the hoist pump doesn't put up enough pressure to bend sch 40.
back to the drawing board.
