Hi, Whose bought an MAF recently for a 1991 fj80 ? Did you use one from a 1993 Camry ? Where did you get one and was it new? Thanks, Mike
Air Flow Meter connection has 6 active pins on a 7 pin connector.If I remember correctly there are 7 wires. Starting from the left side we test wires 4,5,6. Testing for volts,ground and vaf signal. Is that correct? Thanks, Mike
Did you check the easy things first like distributor rotor/cap?Fuel yes, spark is week and orange-reddish .
Hi Mike, I was curious if the 1993 Camary MAF worked? Just had mine fail this week and in the endless search for a replacement.Found an igniter . So the 1993 Camry one worked ? Thanks, Mike
Hey Michael,Forgot fuel pump and filters new. I can’t find any short or rubbing in the wiring.
Same here…..Hey Michael,
I know this is an old thread but what happened with this? I'm having similar problems with mine so I'm curious if you ever got to the bottom of it.
its not a MAF, its a Air Flow Meter.Hi, Whose bought an MAF recently for a 1991 fj80 ? Did you use one from a 1993 Camry ? Where did you get one and was it new? Thanks, Mike
I tried this fix last year and it didn’t work did you have to pop the top and adjust the arm ? I ended up finding a used one that worked until now.its not a MAF, its a Air Flow Meter.
I have a AFM from an earlier model Camry and been in my rig for the last 5 yrs. Works great.
