There really needs to be a 200 series “lean” wiki.
I think there is a lot of good info in this post
Post in thread 'LX570 Lean/Sag'
LX570 Lean/Sag - https://forum.ih8mud.com/threads/lx570-lean-sag.918190/post-12752944
weve learned a bit about 200 series AHC since then, but I think it mostly holds true.
I don’t think it’s worth chasing lean, unless it’s way off, but if I were, I would attack it in these steps. I’ll preface this with a statement that this isn’t fact by any means, but more an educated guess.
1a. Get techstream and connect to tha AHC module. Verify height sensors aren’t in any crazy state.
1. Park truck on flat spot.
2. use techstream AHC module and open both gate valves a couple times with the test utility. This will balance the left and right side of each axles system pressure.
3. Remeasure corner heights. this should let you know if your lean is sensor related or spring related. Possibly could be an ECU issue as well, but doesn’t seem likely.
If you are level at this point, then you should be able to move sensors to get the system pressures after an L to N adjustment to be closer to balanced and the truck should ride level more often, as well as probably make less adjustments on the fly.
If you are not level, then the only real way to get level is with spring adjustments (either spacers or new springs). You could also opt to adjust sensors so that the L to N adjustment gets you similar to the post gate valve measurement Then you would at least lessen the on the fly adjustments.
Honestly I have no idea how precise you can be with making physical sensor adjustments. But if you got with a .5 inches, I’d probably call that good.
