I'd happily take those off your hands. I'll toss in the labor to return them to stock.
Front only BBKs are a common upgrade for many vehicles and I've done them before on other rides. The physical size and appearance is not what dictates bias. Piston sizes internally to the caliper are sized during the development to maintain proper front to rear bias for short and stable stops.
BBKs primary advantages are two fold. Physically larger rotor, pads, and brake caliper for firmer pedal and modulation in braking performance. Additional heat and heat shedding capacity to maintain that performance over repeat brake applications.
As the front does the lions share of braking, that's where the added heat capacity can really pay off.
Nothing about the stock brake calipers are special for off-roading which should say that these Brembos should perform fine in that environment too.
