LX470 ML Speakers fixed for cheap! (5 Viewers)
NY
When i picked up my 2001 LX470 with ML and Nav, I noticed that the drivers door lower speaker would rattle whenever there was bass, almost like it was hitting against something.
The previous owner turned the bass all the way down and switched the audio to only come from the right side of the vehicle to avoid having to deal with it. After doing some digging on Lexus Drivers i noticed an entry that the previous owner had the rear sub disconnected for the same reason. Not knowing if the previous owner had it completely removed or just disconnected, i tore the panel off to take a peak. Sure enough it was just disconnected! I plugged the sub in and sure enough that speaker started rattling. Lucky for me, this saved me from buying a used ML Sub for the trunk. I started testing the speaker and felt the foam detached from the sub around the voice coil. So... i started doing some research. Turns out that foam could easily be replaced!
Turns out the driver side lower speaker and trunk sub for the ML system are the same 6 inch foam size. I purchased the $20 foam repair kit set on ebay (2000-2009 Lexus LX470 Front Door Speaker Foam Surround Repair Kit 86160-0W270 | eBay) in hopes to repair both speakers. I was a bit hesitant that it would fit but even on SimplySpeakers site, the speaker repair kits are the same foam piece.
The kit I purchased included 2 foam trims and the adhesive.
I followed the guide listed here to remove the drivers door to gain access: Door panel removal process
Pretty straight forward, the hardest bit was removing the window control unit but a long flathead will work great.
Tools needed:
Torx screwdriver (T-20 i believe)
Flat head / Philip head driver
X-acto knife or any knife works
This is what i saw after disassembling the door and pulling the foam up. the entire thing was ripped..
I peeled the old foam out and carefully used an x-acto knife to clean the voice coil:
I applied the adhesive to the inner voice coil, laid the new foam down and let it dry for an hour, then did the outer foam and set it in place. I put the gasket back on flipped it over, and used the speaker's own weight to press it down:
And voila the speaker is repaired! i hastily put everything back in trying to contain my excitement and in the process lost one of the screws :bang:. No worry, i found an identical one from the wheel well (surprisingly) and will place an order to replace what's missing.
After putting everything back together, the sound quality has tremendously improved (obviously since it was torn). I cant make a comparison if this actually improved on the initial speaker quality but it sounds great now.
After confirming that, i started on the trunk sub. Some guides will tell you to remove the panel and seatbelt but i simply just pulled the panel off, undid 5 screws and pulled the trunk sub out. I followed the exact same process and was finished in no time. One thing to note is the sub wires don't detach from the enclosure so i had to do it attached, no big deal.
Nothing different with the trunk sub, it was much quicker the second time and was finished very quickly (curing process takes the longest).
Now the Bass in the car is absolutely incredible... I was honestly extremely surprised by how adequate the 6 inch trunk sub was! After playing with the bass settings today, i am keeping it at only 1 bar above neutral, anything more was almost overbearing in my opinion.
So all in all, an evenings worth of work, a $20 foam kit and subs that finally work great now! :bounce:
This was awesome - I’ve never heard of this process but just installed them on all 4 door speakers and I can finally listen to music again!
As a side note, even after repairing the foam around the sub, I have no sound coming from it. Checked the connection and everything seems ok. Any ideas?
I had the same problem as you, after searching google I found if you push the subwoofer in while music is going through it and it starts working the voice coil is disconnected. From my quick research I found voice coil repairs don't last long or don't work at all so I put a wanted ML post up in the classifieds and got no hits. I then bought a new ML sub on ebay. Shortly after installing the new subwoofer, I got a PM that someone had a sub they were willing to sell me but I didn't need it anymore. Side note, the sub is wired into the rear speakers, so make sure there is sound coming out of the rear speakers before you try this.
Don't the 2k LCs have two 4" subs in the rear enclosure?
Just finished this procedure on my front speakers (2003 LC). The rest don't sound blown, but I might re-foam them anyway at some point in the future since I ordered three kits (would have one left over if I did all 5 speakers).
I don't know what they sounded like, new, but they sound great now! No more rattle and distortion. :)
When I pulled the PS door trim off, the speaker looked completely fine!
No visible tears, but it sounded terrible.
I decided to pull it out anyway and inspect it. Well, after poking the foam... It was blown.
So, I re-foamed it with the Simply Speakers kit.
The glue really squirts out of those tubes. Be careful when applying it! If you put too much, it takes much longer to dry, and gets everywhere. Use as little as you can, and give it a few seconds to get tacky before attaching the foam.
Repeated the process for the driver's side speaker (this one was visibly blown), and now my speakers sound great. Before and after (re-installed indoor):
One final tip: the orange padding and plastic ring it is attached to has a notch in it. You have to make sure to account for the notch lining it up on the speaker or it will not sit right when you glue it back on. This happened to me, but I noticed soon enough to rip it apart and position it correclty before the glue dried.
I did not wait the full hour after each step. I waited about thirty minutes. I did wait a few hours before I fired them up in the car though.
They sound great now. No distortion, no rattle, good bass, and they can get pretty loud. All in all, much more cost effective spending $25 on the foam repair kit, than several hundred dollars on new speakers.
@Slashzero @LXFAM This is great info. What volume level did you listen to music at pre and post repair? I’m at like 25-30 on the highway if I really want to hear the music.
Keep in mind, the technology has advanced a lot and newer speakers sound way better than those 25 year old speakers. I know factory look is what we want but sound quality has improved on these newer speakers coming out today.
I’m doing my subwoofer repair right now, I noticed the old foam sat kind of *in* the subwoofer housing, but the replacement phone was a little bit bigger so it’s going to sit *on* the housing
Is that normal?
This got very messy very fast
Update: it was not normal, I glued the stupid ****in foam on top of the stupid ****in enclosure ring that has to home off. The foam goes between the enclosure and the enclosure ring
Anyway, I put everything back together today and got somewhat positive results. It didn’t totally fix my subwoofer, but it did increase the volume at which it starts to rattle. I’ll probably get a new sub eventually
Actually, oddly enough the previous owner bought a brand new subwoofer from a Lexus dealership in 2022. Wtf???
No wonder, when I took the sub out, the foam looked just fine.
Edit. Found the listing might have to tackle this
