LX470 front washer pump problem (2 Viewers)
GCC
Hello,
I’ve got a 04 Lexus LX470 with ~200k and I’ve replaced 2 aftermarket front washer pump and it failed within several days, and third time I replaced it with an OEM part and it failed within 3 days, any thoughts?
Thanks.
Are you sure they're failing and not getting clogged up with junk from the reservoir or something?
Seems very unlikely to have that many failures.
I don’t think so, the motor is not working at all.
If failed means, pump motor will no long work. Even when 12 volts applied directly to it. Check power (wires) coming to pump. Also make sure pump is getting fluid to it. and tubes clear down stream.
How to check wires?
Pump is getting water, and and tubes are clean
