LX470 18" Wheels on LX570? (10 Viewers)
San Antonio, Tx
Website
www.ralphmawyerphotography.com
I've been trying to determine the spec differences, but figured I might just see if anyone has done it with a 100 series 18" wheel on a 200 series.
I did find this and there does seem to be overlapping specs, but not sure about the specific OEM wheels.
Rims for Lexus LX 2007
  • Bolt pattern 5x150
    • Diameter: 18.0'' - 21.0'';
    • Width (inches): 8 - 10;
    • Offset (mm): 39 - 60.
Rims for Lexus LX 2013
    • Diameter: 18.0'' - 20.0'';
    • Width (inches): 8 - 9;
    • Offset (mm): 55 - 60.
I have tried a 100 series wheel on my 200.
It DID NOT clear the caliper. At first I thought everything was good to go, but when I tried to rotate the wheel, it scraped on the front on the brake caliper. The wheels are about 1/32" too small.
This is a LC that is for sale on autotrader that appears to have some older 100 series LX470 18's. So maybe it depends on the specific wheel?
I had these 18s from the toyota 100
Thanks guys, guess I'll just try one and see.
MSCruiser is correct. I attempted to mount 2007 LX470 wheels on my 2011 LX570 and it was a no go. Inside of wheel scraped the outside of the front calipers. The LX470 wheels were the OEM (5) star type 18"
FWIW, the LC100 18" wheels (60mm offset) can fit, but you need to run some spacers to push them out a little bit. Otherwise the back of the spokes interfere with the sides of the front calipers. I'm not sure how thick a spacer you need but doesn't look like much. Maybe 1/4" would be enough.
FWIW, just tried it and 18" LX 470 wheels will not fit on left front of LX 570. Brake Caliber housing rubs, as Marques noted above for the LC100.
Ya... What's interesting is the reverse does work...as I recently sold my 18" stock LC wheels to a guy who put them on his 470.
Not all 18" OEM 5x150 wheels created equal...
Bump.
my wife had a 2007 lx.
I now have a 2011 lx and want her 18” wheels. I was planning on 1.25” spacers to run chains on all 4 corners for winter on old logging road to the cabin.
I did the spacers on my 2010 Tacoma and two 2006 tundras and it worked great. Can’t go over 5 mph anyway.
do the wheels of the 2007 fit the 2011 with spacers?
