- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
I haven't seen a FJC tie rod bent yet, but on the last run a nissan pickup bent one, we straightened it on the rig, bfh and long pry bar.
The IFS rods are small, but solid, so somewhat stronger than a small tube. Around here a lot of IFS rigs play pretty hard in the rocks, the tie rods haven't been an epidemic problem. IMHO if you hit something too hard, I would rather bend a tie rod than break a hub/spindle/rack, tie rods are easy to straighten and cheap to replace.
Some of the locals wheel FJC's pretty aggressively, have broken the normal stuff, diffs, bent rear lower arms, smashed arm mounts, one bent front lower control arm, etc. But they have all driven off of the trail, never had to drag one home. Toyota has been very good about warranty repairs and most of the rigs have obviously been wheeled. They even put a new frame in one that broke in the motor mount area.
IMHO they have proven to be solid wheelers.
The IFS rods are small, but solid, so somewhat stronger than a small tube. Around here a lot of IFS rigs play pretty hard in the rocks, the tie rods haven't been an epidemic problem. IMHO if you hit something too hard, I would rather bend a tie rod than break a hub/spindle/rack, tie rods are easy to straighten and cheap to replace. Some of the locals wheel FJC's pretty aggressively, have broken the normal stuff, diffs, bent rear lower arms, smashed arm mounts, one bent front lower control arm, etc. But they have all driven off of the trail, never had to drag one home. Toyota has been very good about warranty repairs and most of the rigs have obviously been wheeled. They even put a new frame in one that broke in the motor mount area.
