LX 470 Climate Control Reprogramming
Newport Beach, CA
Does anyone have experience in resetting climate control defaults on the touch screen climate control system? The default (when you turn key on) is recirc, and I want to change to fresh air. Also, is there a way to obtain max hot or max cold without hitting the temp up/down button 20 times each way?
Thank you for any assistance.
Mine starts up in the mode that I left it when I shut off the engine. I thought they were all that way? I don't know of any way to hit max hot/cold faster. If you hold down the button, does it toggle through the numbers?
Same here.
Holding down the button does toggle through the numbers, but it's a lot slower than tapping the button a bunch of times. This is one place where the old fashioned dial controls are definitely better.
