LX 450 rear bumper compatibility
Texas
Hi guys,
Did not found a tread, so posting question.
Is OEM rear bumper from LC fully compatible to LX450?
I want to swap mine lx450 rear bumper parts to LC parts.
Are they fully compatible?
The only compatibility issue I could imagine would be the body cladding on the LX450.
I could have taken measurements a month ago before I removed my bumper for an armored dual swing out bumper.
I’m sure someone will chime in shorty though.
What is your goal though? I think the only difference is the center plastic cap covering the four pintle mount holes.
I want to install custom spare tire carier which need driling on one of the side bumper parts and center one.
My goal is to switch to lc bumper, cause lx parts are much rare and if I decide to go back like oem - just return the lx parts which will not be drilled already.
And also lc middle part is not hiding the 4 holes in the frame which I need, so it will be only one driling on one of side parts.
I really want to have way back to oem just in case.
Hi guys,
I believe the rear mud flaps, which LX450 rear bumper integrates into , maybe different. The LX450 rear mud flaps has a housing that matches the fender flare.
Otherwise, no issue that I know of.
Ahh, this is interesting. I have mudflaps and want to use them.
Thank for this info.
Yeah, due to the cladding the flaps are shaped differently to accommodate it. I suspect they could still be used with the LC parts depending on how anal you are about fitment.
