I've always wondered about these heaters, and how they can work. I've never used one before, just had block heaters and once had a circulating heater hose heater.
Anyway, I have a lower rad hose heater on my 1HD-T and it's installed in the...you guessed it...lower rad hose. But, the thermostat lies between the heater and the engine, effectively blocking the flow of heated coolant into the engine. The area around the heater is relatively wide open, so a considerable amount of heat is lost to the air. So how does heat make it to the engine? I'm just not getting it. And it doesn't seem to do much to help my truck on -30°C or colder mornings. The lower rad hose is hot, the thermostat housing is warm, the rest feels cold.
A large percentage of vehicles have the thermostat on the upper hose. On these I can see the heated coolant thermo-circulating through the engine. But on mine...?????
Someone please explain. I'm thinking I need a frost plug type block heater or an actual circulating one because this inline rad hose heater isn't doing much except waste heat and electricity.
as I haven't yet seen the thermostat for my 1HDT
No-one is saying there is no circulation Wayne.
. Plugged her in for 2 hours and even with a less than 1/2 batteries on start up she fired right over
