Low Pressure Power steering line?
Charlotte, NC
Ive recently come into a problem. My low pressure power steering line has decided to give out after 30 years on my fj62. My question is, is there anyone who sells the metal portion of the power steering line? I know it’s a 3/8s line and I can bend one out myself, but if any cruiser companys produce the line aftermarket, I’d rather support them.
Thanks!
Just bolt an aftermarket power steering cooler next to the radiator on the outside. Don't use a transmission cooler - they're too big.
Jpegs.com has a lot to choose from. Doesn't have to be fancy or high performance
which part of the low preasure line?
the rubber hose at the steering box?
the rubber hose to the resevoir?
the metal hard line under the rad?
has the high preasure line been replaced?
Thanks!
YES ,
i carry and stock ALL the OEM Low pressure Return line fittings , right now
it is NOT a /3/8 " ?
its a JIS , double Inverted Flair very special slighted taper too , like a 8-10 % only taper
see below "
thanks
note this is a fj60 parts diagram for general reference
you get the ideas ///
thanks matt
I also have had My SKUNK WORKS LAB , Rising Sun Mechanical ..
faithfully Reproduce in-house with our own 2 hands , the most early of the return like fittings at the BOX itself ...
this is the smallest size toyota toyota made on the MINI truck box , and the FJ40 as well ......
We use Copper Nickle Alloy TOP SHELF grade rust proof tube , hand bend it with hand benders as well ....
we source ALL our JIS threaded service flare fittings straight from JAPAN ........
there triple zinc plated as well
we specialize in Reproduction Toyota NLA / DISC. parts
Here is the USA spec, 8/80-9/87 FJ60LG-KA Low pressure and High Pressure Supply Lines
We have also Reproduced IN-HOUSE the NLA High Pressure Line assy. call out # 44411
OEM SKUNK WORKS Part Re-issue part # 44411-60131-R
only the Best Materials and workmanship make our CUT .....period :cool:
Thanks!
here is your FJ62 Line we also have made custom IN-HOUSE
Hi, Any good hydrulic shop can make any of the lines. Mike
