LOW OIL PRESSURE WARNING LIGHT
Had the pleasure of replacing the pesky water hose and now the low oil pressure warning light is coming on. I have checked the oil level and the oil pressure gauge is showing good pressure. Did I knock a wire loose or do I have an oil pressure issue. Any help is appreciated. Thanks
Your 80 series does not have a low oil pressure warning light. It has an oil pressure gauge. It does however, have an oil level warning light. The oil level sensor is on the left side (USDS) of the upper oil pan near the motor mount. You can easily knock the connector loose while repairing the PHH.
If your oil level is good, the wiring needs to be checked or level sensor probably needs to be cleaned.
^^^^ This should be required reading at first 'sign up' to the forum. ;)
