Low-budget Gear and Sleeping Platform
Monroe, GA
Some of y’all may have read my post about my vertical tire mount solution: Non-welding interior tire storage option I put it through its paces during a three-day camping/riding trip last weekend, and it did fine. However, I was checking out a friend’s shelf unit in the back of his vehicle, and by the time I was driving home, I’d decided to look into building some kind of platform that would fit over a horizontal tire.
I got out in the driveway Wednesday afternoon, cleaned out the back of El Guapo, laid the tire on its side and started taking measurements. At first, my thought was a platform that spanned the entire width of the back. Then after a little more pondering, I decided to focus on a platform that only covered, and rested on, the tire.
I took some more measurements, and then started looking for something about 3’ x 3’ to lie on top of the tire to help me visualize how the final product might look. I was rummaging around in the garage when it hit me – my parent’s old card table! The table was 32” square and fit over the tire perfectly. Well, that got me thinking… instead of a fixed platform, why not something like an old, sturdy card table with the legs cut down so that the underside of the table rested on the tire and any weight on top of the table would be spread over the legs and the tire underneath?!
I like that the table doesn’t go all the way to the passenger side, because I still have access to the side compartment (which holds my portable CB) and the 3rd row seat bracket (which I use as a strap-down point). I’ll also use that space to store my mat, tarp, and small shovel. Then, when I fold down the 2nd-row seat, I have a sleeping platform. And, at camp it could be taken out and used as a table (a short one, but a table nonetheless).
I did some test-fitting with my cooler and some storage bins that I have around the house, and then I ordered a set of Ziploc Weathertight containers (two 15 gallon and two 4 gallon). The two larger containers should fit side-by-side on the table, or one on top of the other. The two smaller containers will fit on top of either larger container. I also took my PVC tire brace and cut it down so that the two smaller containers can sit on it flush with the driver’s rear wheel hump.
Nice work. Very resourceful and looks very useful.
I ordered the Lightspeed Outdoors XL Super Plush FlexForm Self-Inflating Sleep and Camp Pad. It is 77" long, so I needed to pick up a little more horizontal room. I took my small container support frame and added some cross-bracing to it. Now when I swap out the legs, I've got my head support for new pad.
I love resourceful things like this.
Plus you have a table for out at camp. You could get pipe to fit inside the legs to be able to stand it taller. Then pull the pip out and store it in the truck.
Looks doable for weight reduction and easy removal.
I think so. I used the dense/high pressure 3/4" PVC pipe, and my head is the only part of my body that should be resting on the frame. And, I didn't use glue either. The horizontal part of the frame was tamped down with a rubber mallet; however, I just insert and remove the vertical legs by hand.
Plus you have a table for out at camp. You could get pipe to fit inside the legs to be able to stand it taller....
That is a GREAT idea! If I recall correctly, the card table legs are 7/8", so I'll probably try to find PVC pipe to fit over the legs.
Two thumbs up for resourcefullness
I guess I get it from my dad, who grew up during the Great Depression. I've always liked this joke because I've had a few conversations with my dad just like it:
Dad - "Why are you throwing away this chair? All it needs is a back and four legs."
Son - "Dad, it's a tray."
Just dont try to make your tire carrier out of PVC:hillbilly:
No, it's totally doable; however you would have to use bigger pipe, and probably glue it all together. :hillbilly:
But seriously, a couple of years ago I did contemplate trying to turn my tilt-down multi-bike carrier into a tire carrier.
Note to self - dont follow behind rjinga:D
Tada!
I did something like this for a quick turn around trip a couple years ago. I bought some 5/8" OSB (plywood) and cut it into 4 sections. I have 6 plastic milk crates that I have picked up off job sites and used those to support the plywood. Through an air mattress on top and had plenty of room for my son and I. Worked out very well, used the crates to house food, propane, tools etc. Not the most elegant, but cheap and sturdy!
That's my setup right now for when we sleep in the truck. I still prefer ON the truck but sometimes the weather doesn't agree. Also keeps the lookyloos from eyeballing my gear.
