For Sale Louisville, CO: 1999/100 Series with overland set up
Year
1999
  1. 100 Series
Louisville, Colorado United States
Mileage
304000
Color
tan
Price: $16,000 without tent. $18,000 with tent OBO
Miles: 304,xxx
This 1999 100 series Landcruiser (dubbed Natasha) is overland-ready out of the box. It has 304,xxx miles and has been used as it was designed to be used, meaning there are some cosmetic dings and scratches. NOT A MALL CRUISER. I have loved this vehicle and have kept it very mechanically sound, and I hope it goes to someone who will continue using it like a Landcruiser should be used. All stock part replacements were done with OEM parts, some at a dealership and some done by me. Oil was changed every 5,000 miles (I use synthetic 5w30). Differential, transfer case, and transmission fluid regularly changed. The cruiser spent most of its life in New Mexico before I bought it and since then has been in Colorado, Arizona, and California. It spent 2021 in Virginia and Georgia and then back to California at the end of 2021. This truck has a lot of trail miles all over the Western U.S. and will continue to be a reliable overlanding machine for a long time.
Issues:
  • Front seat leather is torn
  • Dent above passenger tail light. Other various small dings and scratches. No accidents, all cosmetic damage is from running trails.
Features and Add ons:
Exterior
  • OME 2.5” lift
  • Rear spring spacers to level
  • Slee diff drop
  • Reinforced rear lower control arms
  • BFG All Terrain tires (285 75 r16)
  • Nitro gear front upper control arms
  • ARB locking front differential
  • Rear electronic locking diff (stock) (both diff lockers are wired into Landcruiser switch with working dash lights)
  • ARB front bumper with 12,000 lb Superwinch
  • Hi-lift mount on front bumper (jack included)
  • Custom rear bumper with spare tire swing out arm with 2” towing hitch receiver and two additional 2” rack receivers (not for towing) and shovel mount
  • Custom modular rack mounted on spare tire (currently configured to carry 5 gal gas can (included) and 5lb propane tank (not included))
  • Custom sliders
  • VIAIR air compressor (under hood) with 2.5 gallon tank (mounted under car in the rear)
  • Bumper mounted airline quick connect
  • ANZO off road lights wired to be used with hi beams
  • Gamivitti Expo++ roof rack (mount for light bar included)
  • Dual battery system with Slee battery tray and National Luna dual battery management/monitoring system
  • Blue Sea Systems fuse box for add on accessories (currently configured to run compressor, off road lights, ARB diff lock solenoid, and added rear power outlets)
  • iKamper 2+ person roof top tent
Interior
  • Stereo: Pioneer AVH-4100 NEX
  • Alpine speakers, stock Subwoofer
  • LED lights in dash and dome/door
  • Air compressor switch and pressure gauge
  • Power inverter
  • WeatherTech floor mats
  • DC power outlet in rear cargo area and USB plugs with direct fused line to aux battery on 10 gauge wire (helps prevent premature fridge shutoff)
  • Custom tailgate lid and gear storage area
  • Custom drawer system (2 drawers, removeable table, and 2 slide out platforms) with tie downs and 25-gallon water tank that can be pressurized using air compressor. Designed so people can sleep in the car.
Replaced (since 2017)
  • Steering rack and tie rods (2020)
  • Front axles/cv joints and seals (2020)
  • Brake booster/master cylinder (2017)
  • Main fuse box (2017)
  • Front differential (when ARB installed) (2019)
  • Driver side front lower control arm (2020)
  • Bushings on front and rear sway bars (2020)
  • A/C, recirc, rear vent, mirror defrost, rear defrost buttons (2020)
  • A/C condensation drain seal (behind glovebox) (2020)
  • Rear driver window actuator/motor (2017)
  • Weather stripping (2017)
  • Spark plugs (2018)
  • Alternator (2021)
Differential lock switch and offroad light switch
Inverter, compressor switch, and gauge
Gear in drawers not included
Compressor and ARB solenoid
Battery management system
