Lots of 55 parts/sale or trade (Colorado)
Grand Junction CO
Tons of pig parts available now for sale or trade. All from either a 12/72 or 1/74 FJ 55 except for final model front doors:
'73 glove box door w/o pad $10
'73 instrument cluster w/gauges $50
Bench seats (2 sets) need recovering $50/set or $25 ea
Never used NOS speedo (early but adaptable to late w/ different cable) $100
Full set of late doors (one piece front window with curved upper front) w/glass and mechanisms and external handles $50 ea (glass for sale separately below)
Front door glass (2) one piece with angled upper front $25 ea
Front door glass (2) late one piece with curved upper front $25 ea.
Front door glass (1 set) early with wing window and main glass both available $35 set
Early double hump hood (very good/no rust) $150
Hood hinges $50
Hood latch mechanism and housing (25)
Hood support rod $10
Cowl vent panel (very good) $50
Rear heater lines $50
'73 starter (works on bench) $20
Tailgate (solid but rough) $50
All OBO, shipping at actual cost from western CO (81506). More to come as project gets underway including frame w/title, front and rear axle assemblies and stock springs, steering column/box/wheel assembly, ignition/signal assembly, inner fenders/radiator support, pedal assemblies, e-brake lever assembly. Possible delivery of/ larger stuff to Denver area, SLC and eastern/southern UT, SoCal or AZ if you're patient.
Needed pig parts, cash or trade:
Grille
Front turn signals and bases
Front and rear bumpers (stock or aftermarket)
R front bumper bracket
R and L outside mirrors
dome light
visors
front and cargo mats
Door and cargo panels
interior door winders
window and door rubber
Trying to make one out of two...let's deal! Send me a PM if you want pics of anything.
I do also have the driver door shell from the'74 Frankencruiser pig, which I think you've seen. Lots of surface rust spots and needing bodywork but no rust through. It's the door with the one piece window, no vent window, and angled top. PM if you want a pic. The full set from Frank is in the same shape, good amount of surface rust, needing some straightening, shells only. The other late model full set is in better shape and includes mechanisms and glass. Those fronts have single piece glass, no vent window and rounded top. Believe the rears interchange through all years.
UPDATE...took another look and you don't want the Frankencruiser's front driver door. Pretty beat up, typical crease and it does have one poorly patched hole. Sorry....
I'm looking for a rear License Plate Light assembly in decent shape if you have one. I've got a 1971 FJ55 and mines pretty well done with cancer. Any help would be appreciated. Thanks
:steer:
Bob:
Is that the single light below the plate or the double lights located on either side?
Only one, from a '74, and I need it for my project. Sorry...
in addition to turn signal bases to convert 40 turn signals to the pig, i also have two grills, not the prettiest paintwise, but will clean up, and a dome light, but the switch knob is missing. $30/pr on the turn signal bases, $5/ea on the grills, $3 on the dome light, plus shipping from denver.
