semlin
curmudgeon
ok, it's official. I'm losing coolant steadily since the truck went back on the road. I hesitated to report it until now because i thought I might just have post-traumatic-head gasket replacement syndrome, but, after I had to add 1 litre to the overflow on Sunday from a cumulative drop from wednesday, I am still seeing a further small drop in fluid in the overflow each day even after travelling short distances. I have smelt the very occasional whiff of burnt coolant on highway driving that might be other cars. I have triple checked the rad and every hose when hot and running, and I have inspected the head/block seam. I see nothing. the engine is running smoothly. oil does not look contaminated and no condensation in the oil cap.
my thoughts are, bad hose fitting only leaking under pressure or a cracked head into the valve area ala doug. I can't really see the new h/g itself failing but i suppose perhaps I did something wrong. the head was pressure tested by the machine shop so hopefully it is just a hose or maybe the rad.
so I'm thinking i need a pressure test or should i go with a dye test?
