12/16/2016 Dealer Toyota 101 280,544
., INSP, *REAR SHOES MACH.DRM, *BRAKE FLUID FLUSH, BODY
0717103REPAIR ORDER NUMBER:
12/14/2016 Dealer Toyota 101 280,529
., *EXPRESS CARE, INSP
0717069REPAIR ORDER NUMBER:
06/27/2016 Dealer Toyota 101 273,825
., *SUSPENSION DIAGNOSI, *EXPRESS CARE, BODY/TRIM
0701834REPAIR ORDER NUMBER:
04/27/2016 Dealer Toyota 101 270,447
., INSP, CK ENGINE LITE (MIL), *BODY TRIM INT.& EXT, OXYGEN SENSOR
0695713REPAIR ORDER NUMBER:
03/23/2016 Dealer Toyota 101 268,649
*EXPRESS CARE
0692668REPAIR ORDER NUMBER:
01/21/2016 Dealer Toyota 101 263,961
CK ENGINE LITE (MIL), *ENGINE MINOR, EFI THROTTLE BDY CLN, *ENGINE ELECTRICAL
0687011REPAIR ORDER NUMBER:
11/17/2015 Dealer Toyota 101 259,867
*EXPRESS CARE, DIAGNOSIS, *REAR PADS AND ROTOR
0681357REPAIR ORDER NUMBER:
Service History for Your 1998 Land Cruiser
DATE SERVICE TYPE SERVICE PROVIDER MILEAGE DESCRIPTION
07/23/2015 Dealer Toyota 101 252,235
*DIAGNOSIS, *EXPRESS CARE, ALTERNATOR, AIR FILTER
0670980REPAIR ORDER NUMBER:
01/19/2015 Dealer Toyota 101 243,006
LUBE, OIL AND FILTER
0654785REPAIR ORDER NUMBER:
08/05/2014 Dealer Toyota 101 233,219
0640126REPAIR ORDER NUMBER:
01/11/2014 Dealer Toyota 101 222,865
., *EXPRESS CARE
0622184REPAIR ORDER NUMBER:
06/28/2013 Dealer Toyota 101 213,333
5000 MILE SERVICE, FRT BRKS VALUE LINE, *REAR PADS AND ROTOR, *FRONT AXLE DIAGNOSI, *BRAKE FLUID FLUSH
0605243REPAIR ORDER NUMBER:
11/21/2012 Dealer Toyota 101 203,713
*DIAGNOSIS, EXPRESS LUBE PLUS, *8CYL ENGINE TUNE, ENGINE ELECTRICAL, WATER PUMP, 8 CYL TIMING BELT, LIGHT DUTY MAINT., REPLACE BELTS
0586483REPAIR ORDER NUMBER:
08/01/2012 Dealer Toyota 101 197,159
., *MULTI-PT INSPECTION
0577248REPAIR ORDER NUMBER:
06/23/2012 Dealer Toyota 101 195,374
LIGHT DUTY MAINT., EXPRESS CARE
0574030REPAIR ORDER NUMBER:
12/20/2011 Dealer Toyota 101 186,204
*FUEL INJECTOR CLEAN, *EFI THROTTLE BODY, AIR FILTER, *WIPER INSERTS, LUBE, OIL AND FILTER, BODY, *BRAKE FLUID FLUSH, *PWR STRNG FLUID FLS
0559059REPAIR ORDER NUMBER:
08/20/2011 Dealer Toyota 101 179,031
., EXPRESS CARE
0549570REPAIR ORDER NUMBER:
04/30/2011 Dealer Toyota 101 173,776
* BRAKE DIAGNOSIS, TIRE PRESS INSP
0540417REPAIR ORDER NUMBER:
04/16/2011 Dealer Toyota 101 173,123
EXPRESS CARE, TIRE PRESS INSP
0539297REPAIR ORDER NUMBER:
12/04/2010 Dealer Toyota 101 167,780
REAR PADS AND ROTORS, BRAKE FLUID FLUSH
0528067REPAIR ORDER NUMBER:
10/30/2010 Dealer Toyota 101 165,957
0525501REPAIR ORDER NUMBER:
05/19/2010 Dealer Toyota 101 157,699
REPLACE BATTERY, LIGHT BULBS
0512003REPAIR ORDER NUMBER:
05/08/2010 Dealer Toyota 101 157,083
EXPRESS CARE
0511066REPAIR ORDER NUMBER:
05/06/2010 Dealer Conicelli Toyota of Springfield
175,550
REAR DAMAGE
0141700REPAIR ORDER NUMBER:
05/06/2010 Dealer Conicelli Toyota 17,556
REAR DAMAGE, FPB
0565060REPAIR ORDER NUMBER:
11/21/2009 Dealer Toyota 101 149,072
EXPRESS CARE
0497094REPAIR ORDER NUMBER:
06/27/2009 Dealer Toyota 101 141,865
140,000 MILE SERVICE
0485191REPAIR ORDER NUMBER:
12/23/2008 Dealer Toyota 101 134,410
130,000 MILE SERVICE
0470663REPAIR ORDER NUMBER:
08/18/2008 Dealer Toyota 101 127,832
120,000 MILE SERVICE, DIFF & TRNSFR CASE, COOLING SYS DRN/REFL, SERV DEPT PROVIDED, BODY, FUEL INJECTOR CLEAN, BRAKE FLUID FLUSH
0460450REPAIR ORDER NUMBER:
05/10/2008 Dealer Toyota 101 123,702
EXPRESS CARE
0452339REPAIR ORDER NUMBER:
01/07/2008 Dealer Toyota 101 118,111
EXPRESS CARE
0441963REPAIR ORDER NUMBER:
10/06/2007 Dealer Toyota 101 114,457
DOOR WINDOW, BODY TRIM INT.& EXT.
0434712REPAIR ORDER NUMBER:
08/18/2007 Dealer Toyota 101 112,108
EXPRESS LUBE PLUS, REAR PADS AND ROTORS, LIGHT BULBS
0430843REPAIR ORDER NUMBER:
04/02/2007 Dealer Toyota 101 108,248
DIAGNOSIS, REPLACE BATTERY, STARTER
0419798REPAIR ORDER NUMBER:
02/17/2007 Dealer Toyota 101 106,849
EXPRESS CARE
0416236REPAIR ORDER NUMBER:
09/02/2006 Dealer Toyota 101 100,245
EXPRESS LUBE PLUS
0403291REPAIR ORDER NUMBER:
04/29/2006 Dealer Toyota 101 96,439
CK ENGINE LITE (MIL), 97,500 MILE SERVICE, BRAKE FLUID FLUSH, BODY, VALVE DECARBONIZE
0393860REPAIR ORDER NUMBER:
01/05/2006 Dealer Toyota 101 92,260
EXPRESS CARE
0385667REPAIR ORDER NUMBER:
08/31/2005 Dealer Toyota 101 87,619
BRAKES, 8 CYL TIMING BELT, ADJUST VALVES 8CYL, FRONT ANTENNA-ELECT, ENGINE MINOR, REPLACE PADS&ROTORS, REPLACE BELTS, WATER PUMP, TENSIONER/IDLER, FRONT OIL SEALS, THERMOSTAT, EFI THROTTLE BODY, 4 WHEEL ALIGNMENT, EXHAUST GASKET
0377043REPAIR ORDER NUMBER:
06/18/2005 Dealer Toyota 101 86,093
EXPRESS LUBE PLUS
0372368REPAIR
