Looking for Odometer KM/H Gear Cluster Only (1 Viewer)
Birmingham
So I took my Speedometer/Odometer Cluster apart to fix the odometer which was stuck. Unfortunately, my odometer does not allow you to remove each individual gear and rolling number. While I was able to remove old grease and lube everything up, it appears that the tooth gear to the single miles must be broken as the only my 1/10th km/h turns. I am hoping that someone out there has just the odometer given that the rest of my cluster is fine. Any help is appreciated.
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
EAST COAST
@kevos37 is the " cluster meter specialist here on MUD " , your in good hands ! :)
The Netherlands
Hi KevO, I have a JO7 model similar problem, I'm based in Europe and look for my gauges to be restored. I want to keep the mileage if possible. Julian
Birmingham
What year cluster? Pictures?
Cheers
KevO
KevO,
Here are pics of the cluster. The turn signal and hibeam lights work fine, but the back lights don’t. If you look closely at the odometer you can see that it has a brass fitting which is on both sides of the spindle outside the numbered wheels. These fittings won’t come off.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
