- Thread starter
- #21
yes, Logan's cruiser is at my house in FV, for the next 3-4 weeks while we work on it.
I'll pick it up from you.I have the side markers. I think i have a decent front turnning lights. If any light cracking but good condition. A set of brake lights.
I have been saving blinker fluid since i started getting landcruisers. The OEM is hard to come by. I have a gallon of that it will be plenty for every corner. It sucks when that is low. I cannot stand it.
So put me down for all that. I will not be able to help if anybody going could take it from clt it will be appreciated
Was about to order the cylinder rebuild kit (got an order I'm about the place with Fat)...but it brings up brake pads???
Toyota part number 04474-60010?
Sorry, I Don't have an answer, I guess someone has a high level database error.
this is what i need.
Diagram 47-06: REAR DRUM BRAKE WHEEL CYLINDER & BACKING PLATE
Part 04474-60010 : CYLINDER KIT, REAR WHEEL
04474-60010 - Genuine Toyota CYLINDER KIT, REAR WHEEL
https://www.amazon.com/Toyota-04474...dp/compatibility-chart/B00KTHK50O?tag=ihco-20
these sites show up as pads
Brake Pads - Toyota (04474-60010) | TPartsOnline
might have to talk to FAT and find out what gives. maybe the part number was superseded or reused.
What are you actually looking for? Cylinder kit or brake pad kit?
I may be able to come up with the headlight this weekend.Parts List if anyone has any part laying around please let me know
- Will add/update list as progress is made.
- left rear marker light (81761-60070) - Rafael has part
- Right rear marker light (81751-60070) - Rafael has part
- L+R Steering relay rod. L(45045-69065) R(45044-69125) - ordered from cruiser outfitters 7/3
- L+R Tie Rod End. L(45046-69135) R(45047-69085) - ordered from cruiser outfitters 7/3
- Left rear slave cylinder rebuild kit (04474-60010)
- Diff Fuild - Jason
-Brake Fuild - eric
-Antifreeze - Eric F
-Trans/t-case fluid
-OEM blinker fluid for a 1991 - Rafael has a gallon imagine that.
- L & R hood struts - ordered 7/3
- Pass side headlight
- lower rear control arm bushings 4 x (48702-60040)
