Logan's Cruiser - and Now The Rest of the Story
Just below the apex
Hey all Garrett here, Since I don’t have my own Mud account, I am having my dad post this for me.
I know it had been spoken about many times, but never acted on so, we went and did it.
We convinced (more like twisted their arms) Kenny and Lydia to allow us to take Logan's truck to our house for some maintenance. Looking at the cruiser, over the last few events we noticed it was time time to give it a little love. Our Goal is to get the Monk’s cruiser back to a level that would allow them to enjoy it on more occasions without worry.
There are a number of items that need addressed and it will take some time to get everything completed in a timely matter, We will be working on this list as we have time but, thought it might be a good idea to have a Hamon and open this up to other who might want to pitch in and turn some wrenches on Logan’s Cruiser. I doubt we'll be able to knock everything out in a weekend so there might be another one depending on the progress. We need to get it completed and returned to the Monk’s before Logan’s run. Everyone is welcome and we will take all help.
I have started 2 lists and adding to both as we inspect the Cruiser.
We want to Thank Johnny @GLTHFJ60 for giving up his Friday night to drive us to the beautiful outskirts of Albemarle to pick up Logan's cruiser and haul it back to my house.
To do List
- Will add/update list as progress is made.
- adjust transmission shift linkage it's not the linkage, the shift lock solenoid is not firing so you have to press the manual button on the selector - will try to locate one
- Gas tank pressuring. - canister fix
- missing A/C box drip tube.
- fix remaining exhaust leaks (trip to Henry's - schedule with Johnny to transport)
- Wiring issues, Seems to be some type of short/miss wired wires. The the left front turn signal turns on in reverse instead of the left backup light. The the left signal indicator lights of on the dash
- complete
- Replace broken Rear side marker lens L+R complete
- Replace Hood Struts (hood will not stay open) - complete
- Need to fix drivers door master switch. Fixed
- replace dust seal steering column/floorboard - complete
- Fix leaking rear slave cylinder - complete
- Flush Brakes - complete
- Install LED light (overhead) - complete
- Replace tie rod ends and drag link ends complete
- replace steering damper - complete
- front left brake caliber - piston sticking complete
- fix front door speakers - complete
- Sand and paint Control arms and sliders. - complete
- Drivers mirror piece need reinforcement. Has the cruiser shake - complete
- install spool in T-case (make part time) - Installed
- replace broken antenna - Complete
- Check drive line ( grease u-joints) - Complete
- reattach exhaust pipes after t-case work finished -- Complete
- install new radiator fan - Complete
- fix broken tab on right fender - Complete
- install front left corner light - Complete
- (replace fluid) Front / rear axles - Complete
- tighten front hubs - Complete
- replace transmission and t-case fluid - Complete
- A/C needs checked out. ( was at 10PSI, just added some Freon. - complete
- check Plugs - replaced
- Flush radiator - complete
Parts List if anyone has any part laying around please let me know
- L & R hood struts - ordered 7/3 Installed
- Brake Fuild - eric - complete
- L+R Steering relay rod. L(45045-69065) R(45044-69125) - Installed
- L+R Tie Rod End. L(45046-69135) R(45047-69085) - Installed
- Left rear slave cylinder - Installed
- Steering Damper - Installed
- Front Brake Pads Installed
- steering shaft lower dust seal - 45292-35050 - Installed
- T-case spool - Jerry - Installed
- left rear marker light (81761-60070) - Installed
- Right rear marker light (81751-60070) - Installed
- Pass side headlight - - Installed
- radio antenna mounted on fender (ordered 86300-60030) - Installed
- Antifreeze - Eric F - onsite
- lower rear control arm bushings - Onur onsite
- radiator fan - Onur onsite
- Diff Fuild - Joe - Installed
- Trans/t-case fluid - Joe -Installed
I might have a door master switch, I'll look tomorrow. It came in a box of misc. stuff, so not sure of the condition either.
Kenny and Lydia took some pics:
@alk747triodad
bU4CdbnX74h43NkKULvXc1GBtpE7r884uwNVIb63jpednGA1mkpQNXIFXkukokdl0UNBCAlFCeJd-vBoLsQeWL-9-ZbgPef83BTJ34xGhJgKSQGGOYP0fmQe_V3Xnrj4vTCr9yT0FjzF0iO7_nhFMXCKA-Z7N_IhRhcypDcKBDUqQMIafzVkmgxJqQIz3tONUY37NpH5toG16zAbt8cACPERPnIe-q8vGPBF_JW5Y0rr_7TaJcdnD67xbK9IacjxLnNGWxRekzBUXiXjihFJy2sfQdgVv9tyjWgjLTpI9vm11PLMZHMuHWZN8Uj-f8eZ1MkwiS-rBIwHJ3uhrkbIApH12IwW8tU4XvOzCUem67CzTuNxUTuUJwuo_q9_2XRINkj7jfAqyDiWqyqIXnI7FYExNW2MmsVggCgb_PlDoJVw4NqJQuv8Eo9V_m0hhLKwd8-QJHwz8E0fLbBH12KVWtTcxw6cd4BjnqNM5RDCpf4NI3beOq399hIcuQTYukRFYAk0UOKLy7Rgs_ybOsJju9-TUowGfyNlPdQpM-4yO4Z03SVoSEvtDrPoJF_YglzRvUEQGznn-BXlQV8OwgmHvqfp_Zd108mG-ND-jE4ofkrvDYjRmSK37w=w1224-h1632-no
Garret did a great job loading the truck onto the trailer, especially without ramps!
FgVYCwjxTWS2_aJIjVwnxNQQvjlhDz915M1N2XIjjpbZA2jhMrxfmu34GofyNfd_H1OM43KHY0-9cvEVzlVcrbNJGoqESeLMqTpJvwnqY1KFdGSbo_qQPncDLFmS1k6Zx6XzNQPxYiYBH_EqZSxmzhWmxhENN2nrXsAWweLUEAx-utFVm0oKgAxj5UnublFz8Nuwfu2cSxI7vxOgoEQgsMAwpsJKFHtxWOQ04KhyquZ2Ix9aEHq1NGWVQTOj2ti761l-ZEi11fJXBLgilfe8kOWOdMgwNn_ZoJ5YelLH4dNcHgBwI5Lvhwoj-sn5CMbj9ayrnVf4INQsJiZHuAgFgPsLDPv02tWG4x4KQBUClkI0bmJzWGpCACfNa20Nz4aYGvJYGXj8--6O546bUB8L_aqq3DquIIADLkHdShB7K-UUSKdUVLjWpIMeQ1fjXccZEWkwo8XdyBgkOKPBmXq672iqR96JtJeBrisfPPPgoemuEiHid7iUfZfFIxl7I-4PgtJ5kQha68ak6a06Ptsv1PHEyv9eM5D_KDJ4OLiG7oHK3tdxiETMBQM0R6HRGwnp8iQSWm86OB6sW_rczas3TUnZQlP8OTl_tSCAyC30flNFqHW9ZRogPQ=w1224-h1632-no
3kJ9nKtSv2ukpv012_21SajeIXnAZSrsUnu9myencS9PE8_0xfXPXRdz6B8GDmnUNmmBshqv48cZZCwcnm37H-Axp_HNbxdKhFTasUzzJd22-D7CYheNp9TlwbzQNcLQ2ZB2KT_RCAb5-scqeny1Tp_40SllrJJi6gADbcKGhJ-I9RbKMxB4QfQ-wnfVM2TiZ-rJ8mPJu7aFlsSDA8YFv12Kk9Y53rdgrmzh3Tcl9A1n0t6OI-xCFpXv8IVn-6NYv9iv8g0VxC8DfaSWcBDFjOqZDKIW1BvyGVvoCdXLDT172ZmRMSQR05YDmaj8DXzHI2qpOvSh0ajHf0r80HcxecX1vAowx8fWw9VQWY2IQCB1G1k-k9FaAcsAlihwUdetGEuZIvjGwDjMzXQeOv0HG4dV6SeEoo7BOaAjKhQbS_VgJSnhKitGcxpIfB6a7ytcA-CGoKSeOOLxG-Gr87tSRdtF6J0oRuW5dGjdiKs5v8Sc0GGkY6JUUJ-wfmjArZ3JtKsvIvgkOqaOToBmacDn5rPQkvq63OLk2VPC34f33YPE0QTKSNPQP6oMcpAZSAeg4Ol89f0mizwcJB8DJOwyxM-TiyN38CU6jz96miXyHlxo-VRCDD5D6Q=w1224-h1632-no
PiaFYp3sg_D3_91-FXuesCOvpnnzBp15oq37C7eoijwiIWUlnzm48jar5HsHIvHLXIu1eNZtjdOls-SGbvXyEuR6cf23UILhe_mfAw8RgieSRqIXr-41Qvyv9Z9EkxU56tl4Vx6yWHByUifHAJXCQKuUYQ8HBTpxxk6XvQW1uiu4Ptao-ihhzA98qbbmPatzXRDoaC_ejgBHgx8qWC03uKcpnevmGrOoObFdGYAEkjX5HFGmOOV9KNNrSDqtkSk8BNSoy055czk5HX93d7keWW7dxAdjPlgIQXoRqjnGeDKB2nJ1N7fl5bZFo5y3nbVHV9BHZP8cEDFnEalswc6Uh9zSyTRJDHkCEhBJ--QL4O3l14OUmpolKkh_4zJX0-nHwH_86oPTYiV6nHASToGsgJJEtDzViBflN8WJX4A3CCKxsLZAltkrbNJqTc_XVhebalhd22HYLsBn0lyQEEy9mm_98pNOumvhv8YW4WZ4ylpGdf2GIa6y7NcD9_YgmcAHlsyDnLq0octZLixDXBIIr9gtkJUN37_YOllHH-v4qN0jn_nXBMxlY_BcgiWnXIP-Xo-baSBxWR03IhxX83tGX2BkdgT99Qrc-_1-u-iQhtF5HgNvyo0-KQ=w1632-h1224-no
I would like to donate parts for this.
Please have whomever is the contact for this drop me a line.
Thank you.
@fourtrax will be in touch with you. I sent him a text as well. Thank you sir!!
I would like to donate some funds for parts/fluids. @GLTHFJ60 what is the best way to send some money?
Send a message to @fourtrax
Still awaiting payment :flipoff2:
Somewhere between kinston and chapel hill nc currently so probably just drove by you guys.
Id be glad to help if it works out with a busy schedule. Might be kinda hard to make it last week now though ;)
7/22 might be a bit more feasible.
Since 91 blinker fluid is NLA Im good for a jug or two of 90w...... just not royal purple
July 16th or the 28/29th work for me also, I just picked a date a few weeks out to allow time to get some parts in. Garrett and I will be working on shortening the list almost daily as we get time. I need to get it back before Logan's run. heck, stop by about any weekend there are tasks to complete.
Would love to pitch in with the labor but that's the weekend of hurricane creek. :crybaby:
I second that. If you guys are wrenching at your place in Fuquay, I'd like to help. @fourtrax do you guys have the truck for a few days? Those of us going on the Hurricane Creek trip can probably help once we get back if the truck is still there after the 23rd. I could show up sooner than the HAMOM to help out too. Let me know.
