nocones,
Describe your problem.
-B-
Step#1 - verify that you have power on both sides of these fuses:
Step#2 - get to auto antenna ECU in P. kick panel
- 15A CIG in D. DASH FUSEBOX
- 15A ECU-IG D. DASH FUSEBOX
- 20 A RADIO UNDERHOOD FUSEBOX
Step#3 - verify that you have 12V when the radio is on, on the purple wire
Step#4 - verify that when you depress the power antenna buttons that you have ground switching to the blu and blu/wht at the ECU. Blu for up, blu/wht for down
Step#5 - verify that when you depress the antenna buttons that you have voltage between the blu/org and the blu/blk ( you must connect your meter leads to both of these wires (black to one wire, red to the other). When you depress one of the antenna buttons you should get voltage and the other direction should give voltage as well but the opposite polarity (usually indicated by a "-" before the voltage reading on the screen)
Let us know how far you get with these tests and the results. We can go from there.
EDIT: I have no way of telling you what voltage to look for as I have no idea what the ECU drops it to. It will be approx. 12V or less if the vehicle is not running.
How do I go about doing step 4? Other than that everything checks out except step 5...no power at the ECU with either up or down button.
hi
I have a similar problem. Just installed a new OE power antenna (previous owner had an aftermarket one installed), but antenna does not go up when radio turns on.
The buttons on the dash does make the antenna go up/down.
Can someone please explain to me where the power antenna ECU is located and how does it look, also size. I cant find it and wondering if previous owner removed it when he installed aftermarket antenna.
Thanks
If you performed all of these tests with no luck getting voltage out of the ECU, it is probably the culprit.
I have the wiring diagram for a 97 LX and it definately shows a relay near the antenna. It could even be mounted to the antenna. Like I said earlier though, I believe it is either for current sensing or possibly height sensing since it is connected with a sheilded cable.
You are at about the limit of what can be verified with a meter without having a known working setup to compare readings with.
I think you're at the point where you need to try a known good ECU and see what happens.
Sorry I couldn't be any more help.
Next Question;
I hate the antenna going up at all when the stereo comes on. I want full control of raising and lowering it.
Any ideas?
Your 97 should remember the last position you left it. So lower it to 1" (or wherever you want it) and it will retract when you turn off the ignition or the radio and it will extend to the last position when you turn the radio on.
-B-
