LJ71 interesting finds
crushers
post ho
Derwent Alberta
so i am getting the left over parts catalogued and put away and i come across some interesting facts:
the flywheel is 2 piece simular to the PZ design
the front and rear driveshafts are exactly the same size
it will be interesting to see how the 2 pc flywheel compares to the PZ in dimensions and design...
cheers
so you saying you may have a 5sp sitting there for your PZ?
when i get a bit more time i want to pull the 4 speed, take the case off and compare with the 5 speed. the cases are identical, the output shafts are identical, the t/case is the same, it seems the counter shaft has to match the gears inside and the imput shaft needs to be swapped over but in a nutshell i think it will be a cake walk (famous last words).
the pilot bearings are the same between the HZJ and the PZJ also...
