I am in the middle of building up an 80 series with a 60 series body. The thread is in the 60s tech under Project Uranus...
I have the 80 stripped down to the driveline and frame just about ready to roll under the body of the 60 series.I hope to have it under there in the next week or so.
The rig has a part-time case and will not need the use of 4wd at high speeds. I am using the 6" slee coils for the project. But for the caster correction I would rather do a cut-n-turn like we do with 40-60series that are sprung over, instead of a drop bracket or correction bushings. This would leave the right caster but the angle of the front drive shaft would be off becuase of the lift. I can deal with the vibration at slow speeds that it will be used for off road. I know the pan-hard will also need to be lenghend which is not a big deal.
Is there anything I am over looking in the front end?
thanks,
-Al
thanks,
-Al
