- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
FJBen said:Ahh,, thats what I was thinking...it seems the correct fix would be to cut and turn on higher lifts or go with true custom setup.
Doesn't matter if you cut and turn, grind the brackets and weld washers, use custom brackets, whatever, when the knuckles are turned the tie rod goes with them and hits the arms, at what about the proper correction for a 4" lift?
With Slee's arms on there currently I have about 1 ~1.5" clearance on the arms and I'm at 4.5* caster. I "suspect" with MY axle (initial caster) I could go up another 3" without too much caster worry...
