What is the correct method to determine what your lift height is? From the ground up? or from the fender down? or what?
Is there a mathematical equation to determine if its a 3 inch lift, 4 inch lift etc?
YMMMVWhat's the difference between new stock and clapped-out stock ride height?
You probably want to post this in the 60 section. 80s don't have leafs or shackles. The truth is there is no universal method of measuring lift height: this thread mentions two, the Toyota FSM has a third, and that's just for the 80 series.Let me pose the question a different way.
I need to purchase new rear shocks for my FJ60, which about 10 years ago I added leaves to the front and rear. Totalling 7 leaves in each front corner, and 10 in the rears. I also installed the longest Triangular greasible shackle extension Man-a-fre had at the time. Are they like 8" or so?
I want to know how much lift I currently have in the rear? ( rear shocks are still good, I think).
BECAUSE. many manufactures state that the stocks are suitable for trucks with a 2.5"-4.0" lift.
I want to make sure that I purchase the correct shock, with the corrects extension and compression travel.
So, how do I measure ( ball park) my current lift?
If you purchase a HD 2.5" lift from EMU, what determines it's a 2.5" lift? How is that measured?
Thanks
