Just a couple of shots. I finally put my used J springs and L shocks on, along with MAF 3" front drop brackets (yes, they're lower than using caster plates, get over it), MAF 2" front bump stops, and my own front sway bar drops. Still nee d to extend the rear swaybar links, and put the extended SS brake lines on.
MAF didn't include instructions with the front drop brackets and I wish they had. I wasn't sure if I should mount them to the frame, then to the arms, or vice versa. I mounted them to the arms first, which in retrospec, might have been the wrong choice. Made it a little tougher to line all the holes up.
I greased all the U-joint / driveshafts, and drove it around a little last night. This morning I had her up to 75 on the highway, no wierd handling, no vibrations. I was really worried about vibrations, since the rig is almost at 180,000 miles and I have no idea if the U joints were ever replaced.
Ride is ok. I think the used L's I got are a bit worn. I may try an alternate shock later - I really liked the adjustability of the RS9000's I had on my Trooper, so maybe those or some MX-6's.
I'll probably eventually put adjustable panard bars on, but priority now is making some slider steps so my wife can actually get in the truck. I can't imagine getting in and out of a 6" lifted truck on a day to day basis. I'm going to have to make a ramp for my dogs to get in the back, or lift the 95lb mutts into the back myself.
Haven't done any real trails, but did climb a ledge near the house that was about waist high. It's certainly more capable than it was on street tires and stock height.
