Yes, you can regear and also do a locker, but you have to essentially get a differential from an older truck to do so.
Question for you. Is it the regearing, the locker or the combination of the two that needs this? Can you re-gear without the locker on the front?Yes, you can regear and also do a locker, but you have to essentially get a differential from an older truck to do so.
@RobW0 are you finding the stock gears a bit lacking after your tires, rack, sliders and tank?
Pretty sure you can regear without the locker - but if in the diff anyway - why not???
There is no gearsets for the 2016+ that fits the rear third member or front carrier in the front diff for the 2016+ truck. So if you want to regear you need a rear diff from an ealier truck as well as a carrier.
Same is for the lockers. However not sure 4.88's are a good match for the truck. I think that is way to much gear. You would be to use the old truck diffs (3.90's) that would be a better ratio than the stock 3.30's in the 16+
Quick follow up. I talked to Al at Nitro today. He said 4.30 would be correct for that tire size with weight and altitude. Mathematically still seems too much, from @bloc's math which is correct. Carl (also from Nitro) advised @benc that 4.30 would be correct on a similar build we are collaborating on in October. Sure they are selling the gears (and they don't offer 3.9s), but I don't think they would lead anyone down the wrong road with their reputation.
As Christo @sleeoffroad mentioned, you have the fitting issues. Nitro does sell the referb (2008-2015) third member and you can have them build it if you exchange cores. I wasn't aware that you have to do the same with the front carrier (a detail that passed me from the March build), but we did in-fact need the T9R replacement carrier in the front, which Nitro also sells.
I threw out an option that we could "upgrade tire sizes" but forgot that the 12.5gal LRA would probably not really allow for anything bigger our 305/65/18s, so that was a dumb statement in hindsight as this build does not call for a rear bumper.
The 3.90 in the pre-2016 LC or 4.6L V8 Tundra could be an option still. If 3.90s become the best viable option/solution, keep in mind the cost would probably (significantly) exceed the Nitro's even me buying them at cost from my parts dept.
Wouldn't mind hearing a little more feedback if anyone has anything else to add.
Again, thank you to everyone for their input.
Eric
Eric
Do you feel this way for an "overweight" 200 spending much time at elevation in the Sierra's? Sounded like the change was just a part specific to the 16+ from Nitro, but if I'm replacing the entire carrier with an earlier unit...am I truely gaining anything? Really trying to get this figured out...before creating an expensive mess I have to clean up later.
