I have been working on some compact, waterproof, low draw LED lights over the past few months. These LED lights utilize 16W (4W per LED) LED's driven by a single driver. They provide a 5 degree spot light. Output is a little over 1,250 lumens and are rated at IP67. They are Cree LED's, full aluminum housing that is powder coated 35% gloss black. Compatible with 12V and 24V systems. Can be ran off your OEM fog light harness, or wired into another circuit. I have mine wired hot with an interrupter switch for the rear lights on the roof rack. For the fog lights I am running them directly off the OEM stalk/harness. Full length cooling fins. I have ran my test unit for 14 days straight with no failure, 7 days inside of a house that was 68*F and 7 days outside in 100*F+ temperatures on the driveway. Immediately after the 14 days I tossed it into a 8ft deep pool to test its thermal shock resistance. No issues. These lights have 9006 connectors (male pins) pre-installed (bare wire by request) and do not come with a wiring harness. I am currently working on designing one. The reflectors do not use a lens (TIR), they utilize a reflector design that captures 92% of the LED output, which is quite impressive considering Rigid uses TIR and only has a few more %'s on efficiency.
A few specs are:
Power Draw: 1.34 @ 12V, 0.67A@24V
Lens is a PMMW (polymethyl methacrylate)
Aluminum Housing
Dimensions:
75mm tall (body only, 87mm with mounting hardware)
80mm wide
82mm deep
Stainless Steel Harware
$125 a pair shipped lower 48, please PM me for payment information.
Have a great day,
Nick
A few specs are:
Aluminum Housing
Dimensions:
80mm wide
82mm deep
Have a great day,
Nick
