This has happened twice now after heavy rains. Water seems to be collecting in the trim piece where the garage door opener panel is. I had dampness on the passenger side floor and cleaned out the sunroof drains and that fixed that. Now I suspect the windshield trim is rusting out and water is leaking through the top of the windshield. It could be a clogged drain again, but the rust above the windshield is pretty concerning.
I attached pictures where the water is leaking from. I also found a screw with a clip on it in the sunroof area by the left drain. Not sure where this came from or where it goes.
Am I due for some body work to get rid of that rust? I did some searching and it seems like I could be missing a rivet or two. I'm not sure if this is the original windshield.
I can only imagine how bad the rust is under the windshield trim. Any direction is appreciated.
