FJ62 Rear axle breather tube is mounted in the stock position. Oil is creeping out the breather and working its way down the tube and into the u-bolts and spring perch. Its not so much that I worry about the diff going dry anytime soon but just as well, Id rather have it working right and not spitting gear oil. Checked the level and the diff isn't overfilled and hasn't taken on any water. I even replaced the tube and breather from a dry truck and oil still is coming out.
The axle has a replacement used differential from a different truck that I dropped in. Drives fine.
Any ideas?
Any ideas?
