Or they just go downI thought the captain always goes down with the ship?
Jim called at 7:14 pm. Thank you Jim
...Jim will build the last set of sliders for me. Yes, the captain will be the last one to abandon the ship!
In all seriousness (someone has to be), thank you very much, medtro, for all your persistence in this, on our behalf. And though you certainly didn't have to be "last in line", I can understand your feeling the need to be... It's been a challenge, I'm sure, being in the middle of all this, and so I appreciate your staying on top of it as best as possible.
And thank you, Jim, for the recent updates and setting ship dates. This has made me feel much relieved about the whole thing...
Now, "bring on the sliders"!!![]()
And now, back to our regularly scheduled comedy hour... ;p
Not the good one.
Well Capt. Jack, did you get your brackets from Kevin?
Ok, upon reinspection I do have the holes in my frame. One lines up fine but the bolt doesn't thread, the other is off like 3/4". I'll mess with it when I have a warm garage to use.
Unfortunately the slider is blocking my view of the holes.... I'll pull it off later today and measure for you.Is the hole center to hole center 4.5 inches apart?
The passenger side slider uses those two bolt holes, on my sliders the mounting plate has the holes too far apart to put both bolts in.What are the measurements for? Are you going to try and use those frame holes for mounting?
Ok, Jackson called me and clarified. My holes on the mounting plate are 4 3/4" apart.
Jim,
Perhaps this is the source of the problem. Can you please check the plate on the new sliders before shipping them out? Thanks!
Ross,
Can you please tell us how you secured the center rigger (next to the cats) on the PS?
It's plenty solid with 2, I put the whole truck on the passenger slider by accident.I have a Slee transfer case skid and was able to use it as a backing plate. I didn't use a single one of the preexisting frame holes for either side. I just thought that the backing plates with the bolts Jim sent acted like a U-bolt. Maybe I installed them in a way that Jim didn't intend, but I would say it is solid after my unintended highjinks at Moab.
