Hi All,
I am at a bit of a loss what to do with my LC200 AB60. A week ago it stopped shifting into 4th gear (in either Auto or S modes). It throws the following codes;
- P0761: Shift Solenoid "C" Performance or Stuck OFF
- P2714: Pressure Control Solenoid "D" Performance or Stuck OFF
I did the following;
- Back to standard tune for engine and trans
- New oil including flush. It did have a light black film on the bottom of the pan, oil and magnets but no real steel shavings in it.
- New wire harnesses (there was some corrosion on the SL2 plug)
- New genuine SLT, SL1, SL2 and SLU solenoids ... the old onses all measured and activated ok but changed just in case ...
- Swapped S3 solenoid with S1 to see if the P0761 "C"/S3 PID moves with the solenoid (they both tested fine). The codes doesnt move.
It is still the same. Shifts really nice 1 > 2 > 3 then nothing ... it doesnt slip or flare ... just doesnt shift up at all ... like it would be locked in S3. Continues to throw the codes above.
So, I took out Techstream
- It can activate all the solenoids
- i tried to shift it manually and strangely Techstream can shift it into 4th (it even allows to stop and takeoff in 4th). Unfortunately techstream only works to 50km/h so I dont know if it could actually shift at higher speeds ...
Would really appreciate any help.
Thank you,
Alex
Thank you,
Alex
