LC100 .. 1FZ-FE with huge Turbo ..
SamoL said:
And what tyres are on those two turbo LCs?
Regards
Samo
they called siam tire .. the best what you can have for the sand .. in USA you called high flotation tire ..
you can have it in 15 - 16 - 17 .. 6 or 8 ply .. they made it in thialand
http://hosting.thailand.com/S00020/
Regards
Samo
Bald...:grinpimp:
I thought you had roads. :confused: :D
hhahahhahahh .. ok ..
they use it because they like the look of it ..and it fill the wheel arch and give that bad ass look :cool:
Is this a truck tire? What size do you drive and what are its speed and load indexes? Is Siam by any chance a Michelin-Siam tire company? Then I might get lucky and be able to order them in Europe. What is the exact name of this tire?
Regards
Samo
SamoL said:
Is this a truck tire? What size do you drive and what is its speed and load index?
Regards
Samo
no its sand tire for 4wd ..
i use 16-9.00 .. thats nearly 285/85 - 16 ..
like i said it come in 16,17-9.00 6 or 8ply .. and the 15 come in 15-8.00 6ply .. in 35 psi street use ..
best for sand 12-15psi
load .. i dont know .. speed i saw some 4wd gose over 220 with it .. i think its 180-200 max.
its heavy in the start but run well over 140 km/h .. and it change the speed meter little bit .. maybe -3 or -5 km/h ..
the tire name is siam tire ..
we have other tire look the same .. like .. dunlop .. bridgeston .. shahen .. the best in order:
1-siam
2-shahen
3-bridgeston
4-dunlop
siam is the orginal one ..
bridgeston and dunlop .. developed the same design after siam .. and done it wrong .. :)
but there bad side in all this tire .. when you stop your ride for long time .. like when you go to bed and wake up again .. they shake the hell off you in the start .. cause that .. the baloon shape off the tire .. but when it heat up all the shake gone ..
This is less than a stock tyre, which can carry arround 2600 lbs. I'd love to have them, but I'm affraid I'd have too many punctures with a fully loaded car on a piste.
So all you have are streets and dunes? ;)
I guess I'll just get BFG A/T for my next trip to Lybia.
Samo
Samo
hahhahahh ..
i dont advice ab=ny body to use this tire in long traveling destance ..
Pirelli is the best .. :D
I've done a bit of searching, and:
Siam tire is owned by Michelin and Siam Cement.
BF Goodrich is also owned by Michelin.
These tires behave exactly the same as Baja T/A tires (they also develop flat spots like you described). The size of the tire on the picture could be 235/85R16. Baja T/A in this size is used by all teams that use BFGoodrich on Paris Dakar Rally. So it seems to me, that Siam tires could be Baja T/A with a different thread pattern.
Regards
Samo
ya .. they look much the same with different thread .. and its said 9.00-16 .. i dont know how much is that .. but sure not 235 .. its 275 or 285 .. i know you can use it on 10inch rims ..
I love the turbo setups.
Do the guys in Qatar use the standard toyota headgasket in the turbo applications? Or are people using copper or Multi layer steel headgaskets. Are there any internet technical forums running currently with the guys from Qatar.
It also looked like two very different turbo setups on two diffrent versions of the 1FZ-FE. I think the coil on plug is the updated version of the engine. Do you have any further information on either turbo setup?
Thanks
EL_3,
Nice 100s, are these Cruisers 100 or 105? Can you please show us the dash and interior if you have pictures?
BTW, I'm going to UAE next year, we will stop first at Jebel Ali, then to Dubai and of course, I will take an all day Safari tour in a Land Cruiser. I love those red sand dunes and hills:grinpimp:
Thanks
they use metl head gaket betwen two standard toyota headgasket .. there is alot off arabic form runing with this kind off mods ..
the coil on plug is relocated to make more room for the custom intake mainfolds ..
4x4CPOSEADOG said:
EL_3,
all off this is 100 with the 1fz-fe engine .. only the 1hd come with solid front .. i dont have any interior pic .. sorry for that ..
you would love it .. they will take you to the "big red" its 100m above sea level .. come in friday and you will see all the guys racing up to the top .. :)
and if you want a 900+ hp LC100 you can have it in a kit .. it will cost 52K USD :D
