LC 200 broken valve spring
Amarillo Texas
Well well! Several weeks ago I wrote about a potential "burnt valve" diagnosis on my 2010 LC 200. But!! The mechanic just let me know that it's probably a broken valve spring. He said the book says you have to pull the head to replace it, but he's mastered a technique where he shouldn't have to do that.
He's not for certain on the broken valve spring but will be tomorrow. All of this is $$$$ good news!
One way that I've seen is to put the piston in bottom dead center and then pressurize the cylinder with compressed air through the spark plug hole. This keeps the valve from dropping while the spring retainer is removed from the valve stem.
How did the spring break without causing internal damage from a dropped valve? I'm sure happy you don't have to deal with that nightmare, just curious what happened?
Many people report periods of misfire codes before things go boom, so it seems some of these operate for a while before there is significant contact. I suspect the problem spot in the spring can get weak leading to reduced spring rate before it actually breaks.
Also I’ve heard of feeding small diameter rope into the cylinder via the spark plug hole and turning the crank to push it up against the valves as another method..
Hopefully I don’t have to try either one.
We don't know that there isn't internal damage just yet.
This is the method.
We’ve had 2 local club members suffer the same issue. AFAIK two different mechanics used the compressed air trick and only replaced the affected spring and keeper
Glad (hope) it wasn’t any worse off
A couple have ended up with new motors.
