Landtank GEN lll MAF housing.
Indicate which option best fit your needs.
  • Own a GEN l housing, need the GEN lll sleeve.
    Votes: 10 66.7%
  • Own a GEN ll housing, need the GEN lll machining.
    Votes: 5 33.3%
  • Total voters
    15
Status
Not open for further replies.
Sorry about the delays guys but I'm at the mercy of the machinist. I prefer to work with small companies or individuals such as myself as I tend to get better product. However personal interruptions do happen.
As far as the benefits, you will see power gains during wide open throttle as shown in the dyno chart. However in the lower RPM range where the chart can't record people see smoother acceleration and shifting and better response.
Like any power adder. making more power means consuming more fuel. So if you are constantly laying into it you will likely see a small drop in economy. I personally don't see any difference but I'm also not using long division to determine that either.
The batch of swap housings have been shipped and I'll be contacting those who have GEN I units for the first swap. Once the people with GEN Is are taken care of we will be moving to the GEN IIs which will only need a turning and the process will hopefully speed up.
Again thanks for your patience.
Any updates on this Rick?
I'll send you an email about my sleeve shortly Rick.
Status
