Landtank 80 series modified fan clutch
Status
Not open for further replies.
VA
Modified OEM Fan Clutch, temperature tuned at 95* per Toyota specifications using 15,000cst oil. All around performance upgrade for cooler engine and AC temperatures.
Order today!
80 Series Modified Toyota Blue Fan Clutch | AJIK Overland Exchange
I just bought one and Josh shipped it quick -- it made a MAJOR difference in temps. Heavy loads are no problem!
Get. Installed one in the midst of my cooling system overhaul (new rad, t-stat, waterpump, hoses, rear heat delete, etc., etc.)
Cruises at 186-188 on the highway at 70. Idles in traffice at 193 and thats after sitting for a few.
A very worthwhile mod...plus Josh will treat you right!
#1900
I had to order one last minute as I destroyed my old clutch. Josh was great, returned my e-mail on a Sunday and sent the clutch out Monday morning FedEx. Great communication and would deal with him again in a heartbeat. The clutch works well also, and was well worth the extra cost to not have to tinker around draining and filling a new one and calibrating (which I did with the old one).
Install procedure? How difficult?
Easy. Just need a 12mm gear wrench.
* remove the four 12mm nuts holding the fan clutch, leave in place
* remove two 12mm bolts holding fan shroud, move forward
* remove fan/fan clutch combo from between the radiator and fan shroud
* swap the fan to new fan clutch, reverse for install
Status
