Landcruiser 300/LX600 Rear tailgate Cargo Interior Light Very Bright
I have been making there kits up for the new Landcruiser 300 in Australia, but they are suited to the Global Markets too.
Price 200AU including postage Australia wide. Other countries I can quote shipping costs please send us a PM for order's
**What you get
LED mounted to new genuine factory trim cover, blue illuminated switch mounted to new genuine factory door grab handle insert trim. Everything you need harness and plug etc.. for connection to exist vehicle wiring.
Kit #1
Fits Landcruiser 300 series Sahara, GR sport, Sahara ZX models with factory **Electric automatic rear lift up tailgate.
Direct plug n play into factory wiring.
No cutting, soldering or running extra wiring or fuses.
2min installation, everything needed supplied.
Kit #2
Fits Landcruiser 300 series VX, GXL, GX
**Non-electric rear door models.
Plug and play into factory wiring, requires the plastic rear back lift up door window surrounds to be removed to run cable through gromet and make connection into exiting wiring.
Comprehensive installation instructions with pictures of each step provided with the light.
45mins installation, everything needed supplied.
**Also no issues if you plan on fitting an electric rear door kit later or already have one, won't affect installation of either.
Perfect for camping fishing or just putting the shopping in the back at night, huge light output
***Fits black Interior rear back door panel, beige on request.
Supplied with new genuine inspection cover and new genuine rear back door handle all ready to go.
Rear 9w LED light operators when rear lift up tailgate opens also has over ride switch on/off to have the 9w LED Light off when tailgate is open.
9w Cree LED Highest Quality -
Best LED you will Find!!
Without the branding for a cleaner finish.
Operational Hours = 50,000+ hours (more than 5 year continuous use).
Aluminum Casing to assist with heat distribution.
120° degree angle Led. Low current draw.
LED lights are ordered with no branding for a clean finish.. they all come out of the same factory Stedi lights etc.
Fused through factory vehicle wiring.
(Blue illuminated) push button switch.
*Light times out after 20mins to prevent battery going flat if left open. Can be reset by simply opening and closing lift-up tailgate.
*Light switches on automatically when lift-up tailgate is open and can be over-ridden so lift-up tailgate is open and light is switched off
**Fitting Instructions provide with Light.
