denis
(O) toyota nut (O)
In some other thread I promised to take a couple pics showing the differences between 2L 2L-2 2L-T 2L-T-2 2L-TEengines. Here's what I have. From what I've seen so far the block is very similar, if not identical between early and late generation engines. The main difference is the cam activation style with either rocker arms on 2L and 2L-T vs. direct activation on 2L-2 2L-T-2 and 2L-T-E. Consequently the camshaft sits much higher on the late style engines, and the timing cover shape changes dramatically, as well as the head cover (stamped steel vs. cast aluminium on the older models.)
1985 2L engine retrofitted with 1988 2L-T parts and 1990+ 2L-T-2 turbo :
