Im having a few problems with my KZJ70. It starts and runs ok but I get a lot of acrid grey smoke on startup and it runs really rough until it warms up and then it runs fine. MPG is definitely down and it seems to be down on power too.
Not loosing coolant or oil.
So far I have:
Changed the fuel filter
Replaced the glow plugs
Checked the valve clearances
Replaced the injectors
Visually checked fuel pump and lines for leaks
Put 60L of quality diesel in the tank
Fuel pick up from tank was replaced about 4 years ago so should be fine.
Compression feels fine (4 definite compression strokes when turning the crank by hand).
Not sure what else to check really and getting pretty tired of throwing good money after bad. Thinking maybe injection pump timing but Im not sure how to check that on this engine/pump?
Any ideas?
So far I have:
Any ideas?
