Kustom koito LED headlight kit in a BJ74
Toronto, Ontario, Canada
Anyone install this in their BJ74? Need some advice as I’m not that knowledgeable about electrical stuff and the instructions don’t take into account the two batteries. When installing do you attach the leads to get 24v from the batteries? The relays that come with the kit are 12v. Any help would be appreciated.
The headlamps will not work on a 24V truck without doing the a combination of the following:
1. Not using the harness that came with the Toyota kit that you were sent. The kit part number is 81110-60P70. They are non-LED from Toyota and have 12V bulbs. These have LEDs so the voltage won't matter. Your high-beam indicator will cease to function with the LED bulbs though. You will need to put a resistor in-line with the headlamps.
2. Find 24v relays that fit into the holders of that Toyota wiring harness. That will be tough to do.
3. Put a 24v-12v step-down system in, use the OEM Toyota wiring harness and the headlamps included and wire the headlighting system as a 12V system.
#3 is the worst option.
#2 will be a more difficult option
#1 will be your easiest, most painless way.
I don't mean to hijack your thread @jetswim but I have to ask if you can just swap out the LED bulbs with 24V ones in this kit?
Like buying 81110-60P70 directly and swapping out the bulbs?
Turns out you don’t need the supplies harness. Just plug and play. Great quality too.
Can you explain more in detail what you did? You just used the kit you bought with the LED bulbs but without the harness?
Yes. The sealed beams have a device between the bulb and the male plug that connects to the harness. Just plug each one into its respective female O.G. harness plug and away you go. The high beam indicator doesn’t seem to show when the high beams are on but they definitely switch to high beams when activated. The provided harness is for a different 12v application I guess.
Yes. s***can the LEDs, add regular 24V bulbs, do not use the harness, and away you go.
I think I will have to agree with you here. I like LED for interior lighting but not necessarily for headlights. I still have the 81110-60P70 kit I got from you so this is good to know.
Thank you for the explanation.
i am just now seeing this thread , any time you or anyone has a Question or Topic to Discuss Regarding my Family Run Online parts
Store , Please Feel Free to shoot Me a MUD pm as well , I have a very open communication and easy to use platform , i DO NOT
SCREEN Other Members or GHOST them and Leave conversions like a OP in this Particular Conversation .......
The LED Kit here under discussion I personally Developed and Named My KUSTOM KIOTO KIT , hence its Kustom in every way
, Both My Water Proof , Glass Encased , Shock Proof , and Properly Aligned and adjusted when i hand build personally each kit , then
bench test for Diodes Alignment in Sync with the KOITO Glass Light House Lens Design Features .
This is the First case of this level of install confusion regarding a 24V Toyota vehicle application , My Bulbs are 100% Top Shelf
and NOT sold on ebay or super bright , i source them abroad and Spare NO expense when it comes to MY Kustom Engineered
end product quality ........PERIOD !
each LED Bulb i Install , has a Compact Heat Sync Resister , thus is CAN BUS capable , i dont have a answer on the high beam indicator ? ........YET but will
my first gut is IT now will require a 24v Blue Tome LED bulb as well ?
but i will Report back when i have concrete facts
Please PM me with further questions or comments .........
i love feedback , but not at the expense of others , as i have concluded this thread was being directed , by well......... a OP 🤔
if My KUSTOM KIOTO KIT needs a Tweek or Adjust , any needed additional part will be supplied at NO incurred cost such as a 24V
Blue tone LED high beam indicator
during this thread post , i have all ready sourced them in both T-5 and T-10 wedge style peanuts
but , need to confirm with My Clients exactly what is proper bulb type ?
My KUSTOM KIOTO KIT is Real , works on 24V Land Cruiser Electrical SYSTEM and changed from high to low beams and normal
function halogens of days gone by
a note worthy note: I chose Not to add the suggestion of Omitting The factory Toyota Supplied sub harness relays from the onset
for Liability Reasons , and if some PO or New owner some how found them selves installing LOW TECH pep boyz halogens back in well
i think the rest is self explanatory ........
again , please feel welcome always to PM me , I will assist in any way i can , and indeed Will Always Have My Clients Back 24/7
kindly
matt
Simply Timeless ......
kindly
matt
[/QUOT
Why don't you just get something like this? And you will probably save alot of money. The 7" LED lights are all 12 or 24 volt from what I have seen. Quite a variety on Ebay... Same size Jeep, Defender, and Land Cruiser. DOT 7" Led Headlight Round DRL Halo Sealed Beam Headlamp For Land Rover Defender | eBay
anything like these for a 70 series Prado, KZJ78?
