Parting Out KS-1993 fj80 cloth abs full float (1 Viewer)
South KC
Parting 93 80 series land cruiser 365k blown head gasket open diffs, but cloth interior, full Floating rear. Spent most of its life in NW but has been in kc for a number of years so some rust but pretty clean.
Clean rims with 285x75r16 tires in good shape 6x5.5
Rear hatch and hood have been swapped out for some with rust Afm, steering wheel, flares spoken for.
Steps are J and J enterprises sst steps. Pretty unique
Leather shifter
head lights? gear box?
Steering gear box?
one light has a rock hit reflector is still good. Little JB weld putty Would seal that up.
Is the driver's side mirror available?
I have one but need to repair it. Floppy and pivot broke. Have repair parts in the works As my DD 80 has the same issue. I’ll be fixing them both at the same time.
Front driver’s side gray floor mat, and a known good front passenger door lock actuator?
No floor mat, but actuator works $60 shipped.
I am interested in the front seats- is the underlying foam still in decent shape, comfortable?
Also interested in both of the shifter handles.
Does the power antenna work and is it available?
Need the full assembly including the supporting angle bracket.
Front seats: passenger is great shape. The driver seat foam is thinner/ smashed a bit On the side piece. with a tear on the side Upright.
Forgot the check it was broken off so assumed it didn’t work.
How about the right rear bumper corner, along with dash panel on the far left side of the steering wheel (the frame around the rear view mirror and dimmer switch)?
EDIT - never mind, these are different between the 93 and my 97. Shucks.
